  • nsak Friend
    #199141
    I see in the JATC Argo page that the latest version 1.0.6 works ok for Joomla 3.2.2 & 3.2.3. Recently I upgraded to 3.2.4 and at that moment I stopped having access to my site (Layout [-1] or not found!) while in the admin (can still login) when I go to the template I see the message
    Warning
    JFolder: :folder: Path is not a folder. Path: /home2/buildin1/public_html/eum/less/themes
    JFolder: :files: Path is not a folder. Path: /home2/buildin1/public_html/eum/tpls
    are we going to have a 3.24 compatible Argo any time soon?
    many thanks!
    TomC Moderator
    #540180
    The thing you need to always remember is that you can’t be quick on the “update/upgrade trigger finger” with ANY template based website …. for this very reason.
    Did you have a complete backup of your site that you could revert back to?
    I will forward this issue onto the JA Development Team for review and further comment as to the update roadmap for JA Argo
    Ninja Lead Moderator
    #540225
    I have checked and get it fixed directly on your site. Below are steps for your reference:
    + Upgrade JA T3 framework version 2.3
    + As the file default.php in templates/ja_argo/tpls folder was deleted, I uploaded original file to your site again.
    Please check and let me know if it helps.
    nsak Friend
    #540232
    Thanks Tom,
    I will restore a previous version, no issue
    However, some roadmap as you say would really help and add value.
    Nikos
    nsak Friend
    #540536
    thanks a lot for settling this!
    Nikos
    alexsmirnov Friend
    #540551
    Hi Nikos,
    <em>@nsak 433964 wrote:</em><blockquote>Thanks Tom,
    …However, some roadmap as you say would really help and add value.
    Nikos
    </blockquote>
    Please have a look at our support life cycle at http://www.joomlart.com/joomlart/product-life-cycle, which I am sure you’ll find useful.
    Regards,
    Alex
This topic contains 6 replies, has 4 voices, and was last updated by  alexsmirnov 10 years, 4 months ago.
