krumz Friend
krumz
- October 2012
- 4 times in 2 posts
December 12, 2012 at 10:30 pm #183072Hello,
I am using Joomla 2.5. It has that nice feature that shows when there are upgrades to new versions. The only problem is whenever it shows there is a new version for JA Products, the upgrade path never works.
So then I come out to Joomlart, look for the product in question – and I don’t see the upgrade is available for download. The last time this happened I left a comment on the page for the module that Joomla showed had a new version and someone here posted the new version.
I am now getting 3 notices for new versions, the upgrades don’t work from Joomla backend, and they are not listed on this site (that I can find anyway). Specifically Content Slider, Slideshow lite, and JA Twitter. I have left comments on each of these module pages but no one has responded. I find this frustrating, is anyone else having this problem??
Also I purchased JA Vintas and it came with content slider and now all the sudden I get sent to a page that states I have to join the extension club to download the new version??
Can someone tell me if I’m doing something wrong?
Thanks.
MoonSailor FriendMoonSailor
- November 2011
- 248 times in 223 posts
December 13, 2012 at 4:48 am #476077Hi Krumz,
<blockquote>
</blockquote>
Some extensions are released along with specific template only – don’t release in Extension Club. Please use “JoomlArt Updates” services in JAEM to upgrade<blockquote>
</blockquote>You can’t upgrade by joomla update since default joomla updates free product only, Please upgrade it by JAEM and go to admin->extension manager -> update > choose “Purge Cache” then “Find Updates” to clear update message from joomla
<blockquote>
</blockquote>
As I said, please use JoomlArt update services to update our JA extensions
January 5, 2013 at 2:36 pm #478546I am having same issue. Tried updating via Joomla backend , got an error message stating
Unknown Archive type
Update path does not exist
JInstaller: :Install: Cannot find XML setup file
Unable to detect manifest fileSo i found this thread and tried to use the JAEM to update. However it says that no update is available. if there truly is no update, how do i clear this from showing up and if there is indeed an update how do i update. the updates in question are:
JA Content Slider Module for J25 & J30
JA Login module for J25 & J30
JA Slideshow Lite Module for J25 & J30
JA Twitter Module for J25 & J30
JA Vintas Template for J25 & J30please advise
- November 2011
January 7, 2013 at 10:21 am #478699Hi computejano,
As I said, please use JoomlArt update services (using JA extensions manager) to update our JA extensions, it does not update by Joomla update manager, Because most of our extension are commercial.
With JAEM,you can read more here : http://wiki.joomlart.com/wiki/JA_Extensions_Manager/How-to#Known_issues
If still error, please send PM to me admin access your site. I will check it again.
you can verify the latest version of each product at http://update.joomlart.com/
ric ordea Friendric ordea
- October 2010
- 3 times in 1 posts
February 6, 2013 at 2:04 pm #482690I’m having similar issues.
I have updated the JA extensions through the JAEM. After I go to the Joomla Extension Manager, Purge Cache, and Find Updates, it pulls the same JA extensions that were previously listed that I just updated. Thank you for assistance.ric ordea Friendric ordea
- October 2010
February 6, 2013 at 2:07 pm #482692Never mind. I found the solution here:
2 users say Thank You to ric ordea for this useful post
Juan Carlos Stauring FriendJuan Carlos Stauring
- 19 times in 3 posts
April 30, 2013 at 11:46 pm #491490<em>@MoonSailor 353807 wrote:</em><blockquote>
With JAEM,you can read more here : http://wiki.joomlart.com/wiki/JA_Extensions_Manager/How-to#Known_issues</blockquote>
I’m not able to update even after following these instructions. Has there been any other solution besides this?
thanks
jcMoonSailor FriendMoonSailor
- November 2011
May 2, 2013 at 6:55 am #491620Hi jcstauring,
Could you pm me admin access of your site? I will check it for you.
July 25, 2013 at 7:13 pm #500165Hi,
I’m using the JA Extensions manager to update all my modules associate with the JA nex template (i.e. JA news featured). So I did the following steps:
1. download all the new updated modules from Joomlart.com
2. upload all the new modules to the repository folder.
3. refresh and check for updates under JA extensions manager.
4. I see the green text says “new version found!”, click on “upgrade now”
5. I got an 500 error message that says” 500 – Internal Server Error -1 – An error has occurred. Copy failed. Return to Control Panel”Do you have any idea what went wrong in my process? Please help, thanks!
Emily
July 25, 2013 at 7:29 pm #500167<em>@MoonSailor 371226 wrote:</em><blockquote>Hi jcstauring,
Could you pm me admin access of your site? I will check it for you.</blockquote>
Hi I had not seen this. Thank you I worked it out some how working with the ja component and changing from local to joomlart service. this was the trick to me entered user name etc and then checked for update, upgraded, cleared cache.
thank you!
July 26, 2013 at 7:04 pm #500269after I’ve done the JA nex template and module upgrade, now all the modules on my frontpage are all mess up…somehow all the positions are wrong and something going on with the footer too..
Can someone tell me why that is? here is the preview link:
http://jlamp.district279.org/Thanks!
AuthorPostsViewing 11 posts - 1 through 11 (of 11 total)This topic contains 11 replies, has 6 voices, and was last updated by osseo 11 years, 5 months ago.
Problem with Joomlart Extension Upgrades
