  • tvicarelli Friend
    #191708
    I installed Ja Fixel with Joomshopping. I have problem with menu creating. If I select a “menu item type” linke Joomshopping Categories or Joomshopping Manufacturers the result is the same: in the form the menu item type is “products” and the page displayed in the front end is the list of categories. Is it a bug= How can i create a menu for manufacturers or a single category?
    Thanks to all
    Tommaso Vicarelli
    swissa Friend
    #510255
    <em>@tvicarelli 395234 wrote:</em><blockquote>Hi,
    Thanks to all
    Tommaso Vicarelli</blockquote>
    It’s a bit confusing the way JS shows its links. It isn’t a bug.
    To pick off a particular category or manufacturer you have to add in the ID. You can obtain the ID for each category from the Category tree in JS and the same with manufacturers. See the right column of this screen shot (albeit an old Tiris with JS).
    Then go to the menu, pick off JS Categories (and yes, it will say Products) and in Required Settings add in your ID. Hopefully the next screenshot helps.
    1. Screen-Shot-2013-10-26-at-12.01.30
    2. Screen-Shot-2013-10-26-at-12.06.24
    tvicarelli Friend
    #510256
    I’m sorry for my english. I try to explain better. I want to show a list of all manufacturers. I select JoomShopping -> Manufactureres
    and I expect a list of MF…
    Why it will say Products?
    1. js_listmf2
    2. js_listmf
    swissa Friend
    #510262
    <em>@tvicarelli 395271 wrote:</em><blockquote>I’m sorry for my english. I try to explain better. I want to show a list of all manufacturers. I select JoomShopping -> Manufactureres
    Why it will say Products?</blockquote>
    No idea. It is how JS is built.
    I just installed fixel J3 and if you pick off manufacturers and then “SHOW” All, as per your screenshot, the menĂ¼ will deliver manufacturers. Or at least it does for me.
    1. Screen-Shot-2013-10-26-at-15.14.17
This topic contains 4 replies, has 2 voices, and was last updated by  swissa 11 years, 1 month ago.
