  • fcweb Friend
    #202098
    hi,
    I made complete website and everything was fine , but after making bio-lingual website by using ja multilingual,
    something changed!!
    I used dj media tool for galleries,and by first page load it works fine but after second refresh it completely crashes. all images stick on the right side of the page and dont work fine .
    i thought it may because of j query conflict so i install “plg_system_jqueryeasy” but the problem still exist .
    would you please check and tell me what can I do? its really important.
    can i change the address of the j query file to be loaded in module or ….
    please it urgent!
    the website is :
    foumanchimie.com
    the error page is eg.
    http://www.foumanchimie.com/index.php/en/household/taromar (first look good but after refreshing the page , problem occur)
    fcweb Friend
    #553077
    NO ANSWER!!! EVEN STAFF??:((:((:((:((:((:((:((:((:((:((
    I have an urgent issue at hand.sb help
    Ninja Lead Moderator
    #553180
    Apologies for this late response but we try our best to reply within 24 hours but sometimes we are not able to cover them all. As sometimes even a simple question can take up hours to debug.
    I spent a lot time to check the problem on your site and see the css style in DJ-ImageSlider module did not load on your site. That’s why you get this bug, you can pm me admin login of your site and FTP account, I will help you to check it further
    Adam M Moderator
    #553362
    Hi @fcweb,
    Since you have submitted a ticket with the same question, please kindly check our answer there instead.
This topic contains 4 replies, has 3 voices, and was last updated by  Adam M 10 years, 1 month ago.
