  • danielfhcom Friend
    #682402
    I have a problem with the design of the footer only when I’m viewing a K2 category. When I access an item or I’m in another window the problem is solved.
    Visualizing a complete K2 category:
    Visualizing a K2 item or another window:
    I have seen that the tag “div” contains the class: “container” and inside is the footer. But I don’t know how to put the footer tag out of that “div”.
    I hope you can help me. Thanks.
    Daniel.
    Hi Daniel,
    The problem doesn’t come from the ‘container’ class in the footer, the culprit is that you have wrong HTML markup in content of K2 item display in that category page. I just checked back-end of your site and saw that you missed a closing </div> tag of this:
    <div class=”itemIntroText”>
    I tried to add and it shows fine now.
    Pls keep in mind that you always add closing tag for every tags used in content otherwhile it will mess up layout.
    Hi Daniel,
    danielfhcom Friend
    #683073
    Thanks Saguaros 🙂
    Daniel.
    danielfhcom Friend
    #748210
    Thanks Saguaros 🙂
    Daniel.
This topic contains 5 replies, has 2 voices, and was last updated by  danielfhcom 9 years, 2 months ago.
