  • matweb Friend
    #706387
    i have a problem with k2 installation
    in “JAK2 Extra fields Filter and Search MODULE”
    appears an error 1146: Table ‘xxxx.xxx_k2_extra_fields’ doesn’t exist
    and in the component if i click to “Update indexing”
    appears an error in a popoup “page 404 COMPONENT_NOT_FOUND”
    i have installed and abilitated also “K2 – JA K2 Filter plugin” and “K2 – JA K2 Extra Field plugin”
    i tryed to reinstall all the package.. at the finish there is an error “XML not found” i think when it install “ja_k2filter.zip.v1.0.0”
    could you please help me?
    Please install first K2 component then install JA K2 Filter and module
This topic contains 3 replies, has 2 voices, and was last updated by  pavit 9 years, 1 month ago.
