November 9, 2011 at 8:54 pm #170555
I am using JA Portfolio template with Joomla 1.5.24 and K2 2.5.1
I have a problem with K2 items layout :
– the layout of the Addthis button at the top (under the title) not displaying properly. There is a bullet and lots of spaces. How can I remove the ul class?
– the social sharing bar at the bottom of the article not showing and I have set SHOW in the category item view.Could you please help me ???
I thank you in advance.
Best Regards
Manuel
- khoand Friend
khoand
- February 2011
- 1166 times in 1060 posts
November 10, 2011 at 3:06 am #423933I can’t access your website by ftp. Do you check it again?
kobenes Friendkobenes
- April 2010
- 29 times in 28 posts
November 10, 2011 at 10:41 am #423986As khoand said, if you provide us live site URL we can help you better.
But also you can try this:
Find /templates/ja_portfolio/css/k2.cssPlease be sure that there is:
list-style: none;
in here:
div.itemToolbar ul li
November 10, 2011 at 2:21 pm #424026Website is http://www.villa-rental.fr
Admin http://www.villa-rental.fr/administrator
need help for example on http://www.villa-rental.fr/index.php?option=com_k2&view=item&id=6%3Avilla-la-plage&lang=enThanks
- April 2010
November 10, 2011 at 2:28 pm #424027Please open your template.css file which belongs to your profile. And add these codes:
.column ul li {
background: none;
line-height: 160%;
margin-bottom: 5px;
overflow: hidden;
padding-left: 30px;
}or you can search and edit your original template.css file as background: none; for .column ul li but this will be changed if you update your template.
November 10, 2011 at 3:58 pm #424057Hi,
I have made the modifications but nothing has changed.
Is it possible someone help me??
Also do you offer help service that I can pay to help me customize my item layout?Thank you very much.
- April 2010
November 10, 2011 at 4:24 pm #424071This modification solves your problem because I check it on your site with Firebug but we should be sure that if this modification in action.
Did you add this code? If so where did you add (which file)?
If you change, where did you make this modification (which file)?Also you can try background: none !important;
Thanks…
November 10, 2011 at 4:52 pm #424080When I have added the code .column ul li … in the template.css I had a problem with layout in the entire website. Try it if you want?! so I was obliged to remove it.
Please help further??!!AuthorPostsViewing 9 posts - 1 through 9 (of 9 total)This topic contains 9 replies, has 3 voices, and was last updated by kobenes 13 years ago.
