  • cougniot Friend
    #158740
    Hi when I try to display a K2 module (example featured products) on the frontpage (left or right) it appears empty.. no content appears…
    All K2 modules ca’t display content except on K2 pages from main menu.
    Could you explain that and give me a solution to display K2 module properly on home page ?
    matwes Friend
    #371854
    Have you checked if your host provider uses PHP Safe Mode On? In such case, K2 may be problematic to run. I have run into that problem myself using K2 (and other components) which forced me to change host provider. There might be a workaround activating ftp layer in joomla which I tried without success.
    /Matt
    aman204 Friend
    #372371
    To add to Matt’s suggestion, Please view::
    http://docs.joomla.org/Why_shouldn%27t_you_use_PHP_safe_mode%3F
    <blockquote>Some third-party extensions may require the specific PHP functions that are blocked by safe_mode.</blockquote>
    So If your hosting provider has enabled safe mode, Please suggest them to turn it off
    Cheers
This topic contains 3 replies, has 3 voices, and was last updated by  aman204 13 years, 11 months ago.
