  • jonasrotilli Friend
    #187106
    Good morning,
    I have a problem in keywords and description in the template JAMizmax.
    Turns out I already put the keywords and description in the global settings but when I open the page and view the source code will not appear these settings, everything appears on the tamplate / framwork.
    In the pages of paper works well, but the home page does not work.
    What should I do to work on the homepage?
    Attached photos showing what I said.
    Since now, thank you.
    1. ProblemaKeyWords2
    2. ProblemaKeyWords1
    jonasrotilli Friend
    #491180
    I found out what the problem was! is that the configuration Metatag Home menu is populated with the data template.
    To fix just open the “home” and edit the meta tag data (keywords, description). = DD
This topic contains 2 replies, has 1 voice, and was last updated by  jonasrotilli 11 years, 8 months ago.
