fdr77 Friend
fdr77
- April 2011
- 3 times in 1 posts
May 14, 2011 at 7:42 pm #164008I have problem with kunena css
firebug tells me that depends on
…/t3-assets/css77890.csshow can I fix this?
fdr77 Friendfdr77
- April 2011
May 15, 2011 at 8:40 pm #391320Can you explain why it takes the css of t3-assets instead the templatecss of Kunena?
with firebug is all controlled by t3-assets and I can not fix it.
With template no joomla art is all ok then the problem is the template joomla jateline
Help megray Friendgray
- October 2009
- 292 times in 230 posts
May 16, 2011 at 6:03 am #391350The JA T3 plugin is compressing and minifying all JS and CSS files.
In order to see original CSS files, go to the template’s back-end and set “Enable Development Mode” parameter to Yes.fdr77 Friendfdr77
- April 2011
May 16, 2011 at 7:42 pm #391503enabled but does not change anything … always t3-assets controls :((:((:((
Phill ModeratorPhill
- February 2014
- 2206 times in 1818 posts
May 16, 2011 at 7:47 pm #391505Please disable the css optimization in the template manager (set it to “No”) then clear the jat3 cache. What is happening is the plugin caches all the css files for speed and this includes the Kunena files. If 2 are conflicting when compressed then we can add a rule stopping the Kunnena ones from being added. First we need to determine by doing the above that everything works without compression.
fdr77 Friendfdr77
- April 2011
May 17, 2011 at 2:25 am #391522solved….thanks
AuthorPostsViewing 6 posts - 1 through 6 (of 6 total)This topic contains 6 replies, has 3 voices, and was last updated by fdr77 13 years, 6 months ago.
Problem with kunena
