  • slukoshkin Friend
    #128930
    Hi all,
    I have problem with language. I need to change some words to Russian. For example I can’t change words “Vote” and “Results” from poll module to russian equivalent. I made changes what I need in default.php from modules/mod_pull/tmpl but unfortunately have no success. As result I got some symbols but not in russian.
    The same story I have with other attempts to change smt. For example word “search…” in search box. Result was the same.
    Could you kindly help me.
    Thank you in advance.
    BR,
    Sergey
    tempusserbia Friend
    #250694
    I think that you have to edit your language file for polls and search button.
    oven Friend
    #252935
    Translation for word “Results” is made through file ru-Ru.ini. Translation for word “Vote” is made in file ru-Ru.mod_poll.ini.
    Personally, I found that Russian equivalents are too long, so i used words “OK” and “ITOGI”
    Sergey
    slukoshkin Friend
    #254491
    Thank you!
    I have already solved my language problem. It was easy – just install russian language. 🙂
    I am very sorry for such stupid question. :rolleyes:
This topic contains 4 replies, has 3 voices, and was last updated by  slukoshkin 16 years, 6 months ago.
