  • Saguaros Moderator
    #970468
    This relates to the configuration for Profiles of each language.
    Previously, you used ‘Default’ profile for both languages so you can see the menu show in one language only.
    I just clone ‘Default’ profile to have a new profile called ‘Default-Englisch’ and assign to menu items pages of English pages only.
    You can see it works now.
    kugelmeier Friend
    #970581
    Thank you very much.
    Do you know the second problem why the contact formular in english is so different to the german?
    I cant find differences in the settings.
    Klaus
    Hi Klaus,
    It due to the settings for the contact form only. You should set it as ‘Plain’ format: http://prntscr.com/cme1z8
    I set it for you and it’s showing fine now.
    kugelmeier Friend
    #971646
    not so easy to understand this but thank you very much!
    Klaus
    You’re welcome!
    Let me know if you need further helps.
This topic contains 5 replies, has 2 voices, and was last updated by  Saguaros 8 years, 2 months ago.
The topic ‘Problem with language’ is closed to new replies.
