  • ferimester1 Friend
    #154964
    Hi!
    Can I set up, that the latest jobs/premium/most viewed module shows only one things?
    For instance: I want to see only the premium jobs, but for nothing I set up in module (choosing premium jobs) but on the front-end I see alwalys both premium and new jobs.
    Best regards,
    Anonymous Moderator
    #357898
    It would be best if you could detail more and send me url, ftp, admin account for further check
    You can send it via ticketID: VMS-748202, (log into http://support.joomlart.com then view your tickets). Your information will be saved and secured.
    Jan Lehnhoff Friend
    #358313
    Having the same error…
    Selected Mode = “Featured Jobs” in mod_jalist_jobs and it shows premium and normal job postings…
    Is the the issue already solved?
    Thanks, Jan
    straightup webstudio
    Jan Lehnhoff
    we-love-joomla.de
    Vinh CV Friend
    #363694
    Dear fidelityhh
    You can download and try the latest JAListJob Module via: http://www.joomlart.com/forums/downloads.php?do=cat&id=137. If have any bug, you can report to us via TicketSystem: http://support.joomlart.com/
    sharpdome Friend
    #366233
    Does the latest version work correctly?
    Can the module be configured to show all latest jobs but keep the premium jobs at the top?
    Vinh CV Friend
    #366252
    Dear sharpdome
    You can try to using latest version via http://www.joomlart.com/forums/downloads.php?do=cat&id=137
    There are 3 options to show jobs in the module:
    – Most views: Most viewed jobs, include premium jobs if it is most view.
    – Featured Jobs: Only Premium Jobs.
    – Latest Jobs: Latest posted jobs, including premium jobs.
    sharpdome Friend
    #366268
    Would it be possible to have a fourth option, with latest jobs but with premium jobs listed first? Similar to the default jobs list view, but as a module that could be included as a tab?
    Vinh CV Friend
    #366279
    Dear sharpdome
    Thanks for your idea.
    We have created an issue to implement the new feature: http://pm.joomlart.com/browse/JAJB-777
    This issue will be release with JAJobBoard 1.5.1
    sharpdome Friend
    #366786
    Could the same functionality you added to the List Jobs module also be added to the List Employers module?
    It would be helpful to have a view showing all the latest Employers, with the Featured Employers sorted to the top.
    Essentially the same as JAJB-777 but for Employers instead of Jobs.
This topic contains 9 replies, has 5 voices, and was last updated by  sharpdome 13 years, 11 months ago.
