  • Pankaj Sharma Moderator
    #907943
    As per your screenshot , i think you are facing issue that some of the articles are open under Hompage .
    A reason behind this issue is that In Joomla if an article or category does not associate a menu item that it will open on the home page . When u click on the article that is open under Homepage . check the url of it .
    You will see the category name and id in url , Because this category does not associate to a menu .
    Do this >
    create a new menu category blog add the category (parent category of article those open in home) in this menu save it and check. Now when u open the article it will open under the Menu that you created now under Home page .
    Hope it heps .
    floti Friend
    #917283
    Hi Pankaj Sharma.
    Thanks for the suggestion. It really helps.
This topic contains 2 replies, has 2 voices, and was last updated by  floti 8 years, 7 months ago.
The topic ‘Problem with Layout Component’ is closed to new replies.
