  • pimenova82 Friend
    #205496
    Hello!
    I have the problem with layout customization. I do everything with instruction:
    V. Customize Layouts
    Step 1: Download the package of K2 Filter Theme
    Step 2: Extract the downloaded package
    Step 3: Copy the extracted folder to: components/com_k2/templates
    BUT, after all steps I don’t see new template ja_k2filter_theme:
    “From back-end of your site, go to: Components >> JA K2 Filter then open Option settings panel. In this panel, please select tab: Search Result Item Layout and select the new added theme in the field: Select a template”
    Please help me to solve the problem!
    pimenova82 Friend
    #566780
    I solved the problem by myself!
This topic contains 2 replies, has 1 voice, and was last updated by  pimenova82 9 years, 7 months ago.
