  • Arno Berwers Friend
    #150143
    I’m trying for weeks to get a problem with the layout solved. The problem is that after adding a product to the cart in Virtuemart, the module on the right side is moved down and further to the right.
    Could you please have a look at this and try to get me a solution? You can add for example a Vigor bike, then choose “checkout” (afrekenen). On the right side the module is messed up.
    Thanks for your help!
    Arno
    #339435
    Dear berwers,
    This problem only appear to you or also on our demo,Please post your url for further check.
This topic contains 2 replies, has 2 voices, and was last updated by  Sherlock 14 years, 8 months ago.
