  • kenkel22 Friend
    #170976
    I am just about to launch my new site. A couple of days ago I created a new layout in the template called gift fayre page in the gift fayre submenu so I could display a full width page. I do not know if this is related to my problem but on the Droid template, the right and left position modules should show side by side to the right of the body position. For some reason now they don’t both show and when one of them does it appears to the bottom of the body area directly under the body position.
    One more thing that I noticed is that there is a white vertical stripe appearing at the bottom to the left of the left most module (down in the dark blue section). I have never noticed that – I am using Safari as my browser.
    Can you help me? I’m not sure if the problem lies in the changes I made in the t3 stuff. I really do not understand fully how to make t3 work together with the pre-defined layout of joomlart templates.
    thank you!
    1. kenkel22screenshot
    himangi Friend
    #434613
    Hi Kelly,
    I tried accessing your site in awstest folder which doesnt have anything and I could not find messed up page on main site
    Can you please provide link where I can see the issue? You can also try to unpublish the articles loading on the frontpage, one by one.. Generally template breaks like this due to MS word code or any other bad code in an article..
    himangi Friend
    #434617
    I havent checked article code but it seems lot of formatting has been done with the articles individually.. Check if any of the articles have any div tags or MS word formatting and remove it..
This topic contains 3 replies, has 2 voices, and was last updated by  himangi 12 years, 11 months ago.
