  • edaunizeau Friend
    #131241
    I currently experience some bad effects with this wonderful layout…
    The naviguation menu on the left doesn’t highlight correctly the selected item.
    Also, the Key concepts menu doesn’t show sub items…
    Any hint ?
    #261796
    hi
    Can you send your URL ?
    #261797
    hi
    edaunizeau Friend
    #261850
    Thanks for your quick answer.
    You can take a look at http://www.gctelecom.fr
    It is in french however you’ll be able to see clearly the problem…
    Also is there a way to have a fixed height of the black bar at the bottom of the screen? (it varies on pages…)
    edaunizeau Friend
    #261852
    I must add the following:
    I switched the site online, but as it is a future production site, I would like to switch it off line asap to continue my work on it.
    Thanks in advance
    #261874
    <blockquote>Also is there a way to have a fixed height of the black bar at the bottom of the screen? (it varies on pages…)</blockquote>
    You can edit template.css (line 1098)
    #ja-footer {
    background:#333333 none repeat scroll 0% 0%;
    color:#666666;
    padding:10px 0pt 30px;-> change here
    position:relative;
    edaunizeau Friend
    #262005
    Can’t find the way to fix this…
    Can you check please http://www.gctelecom.fr/index.php/convergences
    and http://www.gctelecom.fr/
    You’ll see what is my concern: on the convergences pages, the black bottom is very very big… Ideally, having it fixed to a particular size would be more esthetical.
    Cordially
    #262144
    You can add like this
    #ja-footer {
    color:#666666;
    position:relative;
    height:50px;->change as you want
This topic contains 8 replies, has 2 voices, and was last updated by  Sherlock 16 years, 4 months ago.
