  • vidanet Friend
    #124384
    Hi all
    I got a problem with a xstmas template I’ve just downloaded. As you can see from the screenshot attached, the left modules are not shown as they would. Is there something i can do to fix it?
    Lorenzo
    Khanh Le Moderator
    #234529
    Disable Mambot “mos_sifr” will fix this problem. The mos_sifr is use only for Sargas, not Sargas Xmas
    vidanet Friend
    #234541
    WOW thank you. 🙂 now it’s ok! thank you
This topic contains 3 replies, has 2 voices, and was last updated by  vidanet 16 years, 11 months ago.
