  • hanifahmed Friend
    #132473
    Hi – a few problems.
    First of all:
    I have changed and uploaded the Top Menu separators in-between my menu options on the top menu – but they seem to be the only thing that didn’t manage to update.
    Also. My site colour is green. The text is blue (such as the Right Menu links). I can’t find the CSS file anywhere. Is it in the template.css? Help please. Thanks.
    My site (that I am test building it on) is: lowconnectivity.com/ld
    Edit: Two issues fixed – stupidly enough. The above are still relevant.
    jwellman Friend
    #266551
    Hi hanifahmed
    I’m not sure if I can help, but I will try!
    Dropline Menu
    background: url(../../images/grad2-1.gif) repeat-x top #2B6484;
    (The #2b6484 is the blue line color) I believe you can locate it JAEdenite/JA_menus/JA_scriptdlmenu/JA.scriptdlmenu.css
    Also on the blue link color, you can find those codes in the Template.css
    ul.menu li a:hover,
    ul.menu li a:active,
    ul.menu li a:focus {
    color: #2C79B3;
    background: url(../images/arrow2.png) no-repeat 97% center;
    hanifahmed Friend
    #266557
    Thanks jwellman.
    The colour of the link change worked fantastically – but the blue is still visible in the main menu!
    It seriously is bugging me.
    Thanks.
    jwellman Friend
    #266567
    I hope I’m telling you right… if not perhaps a moderator will assist. Did you find the menu folder? It is not in the CSS template. You may not even have access to it… ?? It is located in your Cpanel. Someone correct me if I’m wrong. :confused: Perhaps she can reach the menu file through the template??
    I am still showing the blue color has not been changed in the menu folder.
    It is still showing the blue color. Here is a link to the CSS I’m viewing:
    http://lowconnectivity.com/ld/templates/ja_edenite/ja_menus/ja_scriptdlmenu/ja.scriptdlmenu.css
    /* Script Dropline Menu
    #ja-subnav ul {
    display: none;
    #jasdl-mainnav {
    position: relative;
    #jasdl-mainnav ul {
    margin: 0;
    padding: 0;
    #jasdl-mainnav li {
    float: left;
    padding: 0;
    margin: 0;
    background: none;
    border-right: 1px solid #75AAD2;
    #jasdl-mainnav a {
    display: block;
    float: left;
    text-decoration: none;
    line-height: 32px;
    padding: 0 20px;
    color: #C3DBED;
    font-size: 100%;
    font-weight: bold;
    border-right: 1px solid #2B6484;
    #jasdl-mainnav a:hover,
    #jasdl-mainnav ul li.hover a {
    color: #FFFFFF;
    #jasdl-mainnav li.active a,
    #jasdl-mainnav li.active a:hover,
    #jasdl-mainnav li.active a:active,
    #jasdl-mainnav li.active a:focus {
    color: #FFFFFF;
    background: url(../../images/grad2-2.gif) repeat-x top #91AE4E;
    hanifahmed Friend
    #266569
    Jess, thanks for replying.
    I did it change it before but realised it did not upload – so it didn’t update it to the new one.
    I did manage to update it and upload it now – but still with no succes.
    I have seen other people who have managed to do this on their Edenite sites – so I know it is possible.
    jwellman Friend
    #266614
    I looked at topics in the Edenite forum and found this:
    http://www.joomlart.com/forums/topic/top-nav-menu-bar/
    Perhaps it will help you as well.
    hanifahmed Friend
    #266669
    Fantastic. Thanks very much.
This topic contains 7 replies, has 2 voices, and was last updated by  hanifahmed 16 years, 4 months ago.
