ditser Friend
ditser
- January 2013
- 2 times in 1 posts
April 24, 2015 at 3:59 pm #205804Hi,
I have problems when I want to customize the T3_bs3_blank template, first I put the template setting in enable mode and disable theme-magic to use only less files, then I made the changes in the template/Less/ folder and created new Less files to get order, but these new files are not mapping in the “t3-assets/Less”, also I create a Folder called ?extras? like I saw in the template ja_cagox, but the files does not show in ?t3-assets/less? folder. My Less files are well imported from a vars.less files, so I don?t know what is the problem.
Also I enabled the develope mode in the ja_cagox installation and the Less files are well mapped in the “t3-assets/Less”
Thanks in advance. :confused:
T3_bs3_blank
T3-assets Fodler
Ja_Cagox Instalation
- ditser Friend
ditser
- January 2013
April 24, 2015 at 7:24 pm #568238Hi,
I found the solution, there is a setting in T3 Template called Addons Extra Style, I select Virtuemart – All pages and the less files were mapped by T3 Framework.
Thanks In Advance
ditser Friendditser
- January 2013
April 24, 2015 at 7:24 pm #733334Hi,
Thanks In Advance
AuthorPostsViewing 3 posts - 1 through 3 (of 3 total)This topic contains 3 replies, has 1 voice, and was last updated by ditser 9 years, 6 months ago.
