June 15, 2010 at 6:31 pm #151821
Hi!
I am trying to make the slideshow bigger – however the mask will not follow
You can have a preview here:
http://www.tracksfortravelers.com/
The mask is still the smaller size. i found some thread on this but no precise solution yet
Help…
thanks!
Christian
Sherlock FriendSherlock
- 2478 times in 2162 posts
June 16, 2010 at 10:44 am #347244Hi syncrocrick ,
The slideshow Mask has an background and I think you have to make adjustment on that background.
June 17, 2010 at 5:12 pm #347398<em>@dathq 183065 wrote:</em><blockquote>Hi syncrocrick ,
The slideshow Mask has an background and I think you have to make adjustment on that background.</blockquote>
Thanks – could you tell me where I make this adjustement? I can’t seem to find it.
uniquebiz Frienduniquebiz
- February 2010
- 156 times in 119 posts
June 18, 2010 at 12:08 am #347416syncrocrick;183255Thanks – could you tell me where I make this adjustement? I can’t seem to find it.
Hi syncrocrick
look in templatesja Rasiteimages folder for slide-mask.png that’s the file you should make bigger. Do not forget this .png has transparency which must be preserved when exporting the new size
Blessings ShannonJune 18, 2010 at 4:08 pm #347465<em>@uniquebiz 183277 wrote:</em><blockquote>Hi syncrocrick
Blessings Shannon</blockquote>Shannon,
It makes sense. I did change the size of the image but unfortunately that did not solve my problem. Would you have any other suggestion?
Can I just turn the mask off? Or is there a sizing parameter in the files somewhere?
Do I need to clear a cache somewhere?I am at loss.
- February 2010
June 18, 2010 at 11:45 pm #347482syncrocrick;183347Shannon,
Delete teh mask and see what effect it has, I did this in Pyro and had no problem
Cheers ShannonJune 19, 2010 at 12:14 am #347483<em>@uniquebiz 183373 wrote:</em><blockquote>Delete teh mask and see what effect it has, I did this in Pyro and had no problem
Cheers Shannon</blockquote>You mean to delete the actual .png file? Yes I tried that already and it did not help. But I’ll try again.
This topic contains 8 replies, has 4 voices, and was last updated by Saguaros 14 years, 4 months ago.
