ibrahimbdawy Friend
ibrahimbdawy
- November 2008
- 18 times in 2 posts
December 13, 2009 at 7:43 pm #146812Hello all
There is a problem I can not be resolved ,
When to Use wibiyatoolbar sometimes the mega menu opens and many cases it does not work
I’ve installed wibiyatoolbar plugins But same problem !!
and by adding code in the file layouts/default.php
but the same result
http://www.joomlaeyes.com
Is there a solution to this problem?
Note
I am now turned off
Because I need to mega menu work
- 2008 times in 1700 posts
December 14, 2009 at 10:55 am #326525Hi there
Please chekc this thread: http://www.joomlart.com/forums/topic/wibiya-and-janews2-module/
Hope it helps.
1 user says Thank You to JA Developer for this useful post
ibrahimbdawy Friendibrahimbdawy
- November 2008
December 14, 2009 at 12:17 pm #326533Thank you very much You are always a great man:D
it works for nowAuthorPostsViewing 3 posts - 1 through 3 (of 3 total)This topic contains 3 replies, has 2 voices, and was last updated by ibrahimbdawy 15 years ago.
Problem with mega menu
