jp Friend
jp
- April 2012
- 5 times in 2 posts
August 25, 2015 at 8:00 am #665094Good day
For some reason my megamenu does not work properly. it looks like the default menu. does not look appealing at all
maybe am doing something wrong.
Is there also a way to make the space the menu sits in bigger so it doesn’t not go into a next line
Thanks in advance
JPPankaj Sharma ModeratorPankaj Sharma
August 25, 2015 at 10:29 am #665137Hi
The mega menu already using the span10, max space , now you can reduce the padding between the menu items , so it all menu item comes in line .
Add below code in custom.css
.t3-mainnav .navbar .nav > li > a {padding: 16px!important; }
August 25, 2015 at 10:29 am #746528Hi
jp Friendjp
- April 2012
August 25, 2015 at 12:26 pm #665393Thank you that did the trick
Now just the look of the mega menu itself under the dropdown of “contact us”
jp Friendjp
- April 2012
August 25, 2015 at 12:26 pm #746542Thank you that did the trick
August 25, 2015 at 4:12 pm #665427<em>@jptromp 489037 wrote:</em><blockquote>Thank you that did the trick
Now just the look of the mega menu itself under the dropdown of “contact us”</blockquote>
Hi can explain in details what u mean by contact us drop down , u can fix the issue with my solution given in last post.Pankaj Sharma ModeratorPankaj Sharma
August 25, 2015 at 4:12 pm #746575<em>@jptromp 489037 wrote:</em><blockquote>Thank you that did the trick
Hi can explain in details what u mean by contact us drop down , u can fix the issue with my solution given in last post. -
This topic contains 9 replies, has 2 voices, and was last updated by jp 9 years, 2 months ago.
