  • roma7000 Friend
    #695682
    After a update from T3 Framework from version 1.4.3 to 2.5.1 .
    The submenu in the Megamenu changed
    And this one is after the update
    The difference you see at the Uitslagen menu.
    The tekst is different and the arrow is missing.
    Please help to solve this problem
    Ninja Lead Moderator
    #695783
    I’d like to take a look directly at your site maybe I will suggest the solution for you, you can pm me the URL of your site and admin login info.
    #750852
    #750970
    I have rollbacked T3 framework to version 1.4.3 on your site to check the problem with megamenu but frontend is working blank page. I tried to override to install T3 framework version 2.5.1 but I got this bug
    Beside that your site access at my end is very slow and hard to debug the problem on your site.
    I need to rollback your site with T3 framework version 1.4.3 to compare it with 2.5.1, maybe I will find the solution to solve the problem on your site.
    roma7000 Friend
    #751037
    Dear Ninja Lead,
    I have restored T3 1.4.3 the website is working again.
    The problem starts after T3 2.0.0
    And i guess you did get the error because you tried to update a Joomlart extension with the normal joomla updater.
    So far as if i know you have to update it with Joomlart extensions manager and thats working fine.
    Not Joomla art extensions update fine in the Joomla update you used.
    But to downgrade T3 i have removed it and download the 1.4.3 from this website.
    And installed it again.
    Greetings ROMA
    #751083
    Thank you for your rollback T3 framework on your site is version 1.4.3, I see some css style from T3 framework 1.4.3 and 2.5.1 are different, I need to compare it from local at my end.
    I tried to install Akeeba backup on your site but I got this bug
    roma7000 Friend
    #704284
    Dear Ninja
    Problem is solved.
    The problem lies in megamenu.tlp.php and megamenu.php.
    I copied the 2 files from 1.4.3 into 2.5.1 and i placed megamenu.less to because of a error in Theme Magic
    Greeting Roma
    roma7000 Friend
    #751230
    Dear Ninja
    Problem is solved.
    Greeting Roma
This topic contains 8 replies, has 2 voices, and was last updated by  roma7000 9 years, 1 month ago.
