  • dradameks Friend
    #170208
    I have a problem with the mega menu. After installing the slider is under megamenu slider. Slider hides the menu. I am writing once again.
    Support wrote that I have set the z-index. Do not write where to look. I was looking for z-index but I have found. Please help. I’m using the JA-minisite template. I wrote to Support a few times.
    TomC Moderator
    #422473
    It looks as though you’ve installed a different slideshow component into your website – is this so?
    I tried checking for which CSS you might need to modify, and I come up with the following . . .
    sot-slideshow-cover-108 {position:relative; overflow:hidden; width:100%}
    Though, due to this component being installed separately, it is difficult to identify where the CSS is that you would need to add a “z-index: 1;” parameter for.
    Can you advise as to what slideshow component you are using?
    khoand Friend
    #422474
    Could you give me a link to your page as you said?
    TomC Moderator
    #422475
    <em>@khoand 279833 wrote:</em><blockquote>Hi,
    Could you give me a link to your page as you said?</blockquote>
    Here ya go, khoand . . . http://maxmania.pl/
    dradameks Friend
    #422933
    Sorry. I can’t find this line. I was looking for but don’t know where it is. My page is maxmania.pl
    Thank y
    TomC Moderator
    #422956
    <em>@dradameks 280427 wrote:</em><blockquote>Sorry. I can’t find this line. I was looking for but don’t know where it is. My page is maxmania.pl
    Thank y</blockquote>
    Did you look within the K2 Slideshow component you are using?
    dradameks Friend
    #422965
    I use the module. This is module made ​​by Skyoftech. This is llink.
    TomC Moderator
    #422969
    <em>@dradameks 280472 wrote:</em><blockquote>I use the module. This is module made ​​by Skyoftech. This is llink.</blockquote>
    I understand this . . . and as you installed this module, then the installation created the module file within your site files on your server. Therefore, you should be able to look into that module’s folders/files and find the file that contains the CSS you need to modify.
    Make sense?
This topic contains 8 replies, has 3 voices, and was last updated by  TomC 13 years ago.
