  • robyrom Friend
    #198213
    I have added a column in the megamenu and I have copied a “testual separator ” voice. The new one is displayed with a different class of css and it looks smaller: why this beavhior? If someone wants to have a glimpse the url is http://www.liceogmarconi.gov.it/joomla3. Thanks
    TomC Moderator
    #536868
    When you say you “created a column,” do you mean a new main menu item with child/sub menu items?
    robyrom Friend
    #536876
    <em>@TomC 429500 wrote:</em><blockquote>When you say you “created a column,” do you mean a new main menu item with child/sub menu items?</blockquote>
    I created a column via the mega menu. The voice menu then has been made as sub menu item.
    TomC Moderator
    #536877
    <em>@robyrom 429509 wrote:</em><blockquote>I created a column via the mega menu. The voice menu then has been made as sub menu item.</blockquote>
    Did you create the main menu item – and then sub menu items – exactly like the menu items you already have established?
    robyrom Friend
    #536882
    <em>@TomC 429511 wrote:</em><blockquote>Did you create the main menu item – and then sub menu items – exactly like the menu items you already have established?</blockquote>
    I have simply duplicated a sub menu item “text separator” type
    TomC Moderator
    #536883
    Here is a Guide as to how to correctly add menu/sub-menu items —> NAVIGATION
This topic contains 6 replies, has 2 voices, and was last updated by  TomC 10 years, 7 months ago.
