May 12, 2015 at 9:46 am #570304
Yet that’s because when I encounter that the menu layout has been screwed up again I am correcting it again.
But now I have added a new item to the menu and the megamenu for registered is still correct but the layout of the megamenu
has been lost it’s width congiration again for the group Special.Here you can see that the width of 700px has been lost again for the special group
while the megamenu for registered group is still correct.
Again this only happens for the group Special. Every time it looses it’s width value.
Where does Megamenu saves the input of these values? Does it write it to some css file?
What file is responsible to read and write this input?-
May 15, 2015 at 3:41 am #570619It’s really weird as when I try to create a new menu item called ‘FAQ(2)’, the menu still shows properly in megamenu configuration section: http://prntscr.com/75cys1
Saguaros ModeratorSaguaros
May 15, 2015 at 3:41 am #735682It’s really weird as when I try to create a new menu item called ‘FAQ(2)’, the menu still shows properly in megamenu configuration section: http://prntscr.com/75cys1
March 29, 2016 at 8:27 am #906069Hi, i have the same problem. Did you solve it yet?
March 29, 2016 at 8:30 am #906076Hi
You can clarify the steps to replicate the issue on your site and also send me the login info via PRIVATE reply so I will have a look.
This topic contains 21 replies, has 3 voices, and was last updated by Saguaros 8 years, 7 months ago.
