December 25, 2016 at 3:26 pm #997123
Hi, please help as I have problem with configuring the megamenu. This problem occurs in the quickstart installation I have locally too. As see in the attached image, the submenu of "entertainment" is not displayed it’s supposed to be. I followed the instructions in the documentations already and set the left column to 2 and right column to 10. A way to replicate the problem is that you can try to add submenu to a quickstart installation on your side and you’ll see what I mean. Hopefully it’s only my problem that can be corrected easily. Thanks.
- November 2014
- 3854 times in 3563 posts
December 26, 2016 at 2:06 am #997254Hi,
You can follow the step below
Go to Admin -> Extensions ->Templates -> JA Teline V Default
- Click megamenu button, check and add the value as my screenshot: http://prntscr.com/dnvvyp
December 26, 2016 at 5:54 am #997302Hi thanks for your reply. I did exactly the same thing and it generated the result as I show you. Maybe you can try adding submenu to "entertainment" and you’ll see what I mean. Thanks again.
- November 2014
December 27, 2016 at 1:43 am #997499Hi,
JA Teline V template is a special template and it loads the module under the menu and it does not support to load the submenu
For example:
- Entertainment menu loads news-entertainment position: http://prntscr.com/do9x7h from Entertainment menu: http://prntscr.com/do9yb3
and it could not load submenu with this setting that’s why you got this bug on your site.
AuthorPostsViewing 4 posts - 1 through 4 (of 4 total)This topic contains 3 replies, has 2 voices, and was last updated by Ninja Lead 7 years, 9 months ago.
Problem with megamenu
