  • kokosz_mk Friend
    #155051
    Hi all
    I’m using dropline menu and I have “little” problem.
    Please look at this links to check the problem:
    menu ok
    menu bad
    Some positions of menu are not displaying ok, what’s wrong ?
    Thanks for help
    i only see a issue with the slected menu item, with menu bad link you gave.
    1) That link is using for display articles of section, i think that the section is not related with a menu item in the main menu, so that you need to create a menu item to do this
    2) or it has conflicting alas, you try to check again
    kokosz_mk Friend
    #358357
    You’re right. I’ve got conflicting alias for menu.
    Thanks a lot.
    The problem is over.
This topic contains 3 replies, has 2 voices, and was last updated by  kokosz_mk 14 years, 1 month ago.
