  • kyovev Friend
    #170640
    Hello, i did some modification of the template and here it is
    zaribenshop.com
    but for some reason the left menu is not staying correctly when i have less than 16 items
    http://www.zaribenshop.com/%D0%90%D0%BA%D1%81%D0%B5%D1%81%D0%BE%D0%B0%D1%80%D0%B8.html
    when i have 2 pagination pages everything is ok, but when i have 3-4 products it just crashes.
    The structure of the template is not touched in the development process – i just added some module positions and did some styling, but the main structure of the template is the same.
    I have cleared all the floating for this menu.
    It’s the same with the search – when i search for something are there are less than 2 pagination pages the menu is just broken.
    So…would you please help me to solve this problem with the left menu?
    himangi Friend
    #425242
    Can you please provide a link where I can see the left menu is not displayed correctly so that I can compare the correct and incorrect pages?
This topic contains 2 replies, has 2 voices, and was last updated by  himangi 13 years, 1 month ago.
