noekisho Friend
noekisho
- July 2012
August 25, 2014 at 2:42 am #200766When i clic in menu “servicios” (our services) i got this error: Parse error: syntax error, unexpected T_STATIC, expecting T_STRING or T_VARIABLE or ‘$’ in /home/pcexpressm/domains/pcexpressmexico.net/public_html/plugins/system/t3/includes/joomla25/layout/file.php on line 436
Link:http://pcexpressmexico.net/
or when i clic in any of the icons.
Thanks a lot
Adam M ModeratorAdam M
- May 2014
- 1271 times in 1235 posts
August 26, 2014 at 3:54 am #547239Hi,
Could you please provide which PHP version are you running ?
noekisho Friendnoekisho
- July 2012
August 30, 2014 at 1:25 am #547712Hi
Vesión PHP 5.2.17Best regards
- July 2012
September 1, 2014 at 4:28 pm #547887<em>@Adam M 442894 wrote:</em><blockquote>Hi,
Could you please provide which PHP version are you running ?</blockquote>
Version runing PHP 5.2.17
- May 2014
- July 2012
September 6, 2014 at 12:30 am #548551<em>@Adam M 443760 wrote:</em><blockquote>Hi,
Since the minimum requirement for Joomla! 2.5 is PHP version 5.2.4 or above, you might have to contact your hosting vendor and update it for you, you can see it here.</blockquote>
You´re right i change the version and the issue is gone.
Thanks a lot
AuthorPostsViewing 6 posts - 1 through 6 (of 6 total)This topic contains 6 replies, has 2 voices, and was last updated by noekisho 10 years, 1 month ago.
Problem with menu
