test melih
 melih
  • desmats Friend
    #1079731
    Hi chaps,
    I had to switch off the mega menu feature on the main menu as it was getting too large.
    I now have an issue when on this page http://www.focus-sb.co.uk/Brochures-and-Price-List when trying to navigate away from this page the roll over sub menus do not appear. For example when you hover over ABOUT the menu does not drop down – if you click it does drop down but then the sub menu ABOUT>OUR PRODUCTS does not reveal even if you click it. This only occurs on the page mentioned the menus work fine from any other page.
    As I can see that there is conflict in JS on your site: http://prntscr.com/hkm1yl
    Could you try to temporarily disable 3rd party extension on your site first? as it may load additional jquery and cause the conflict.
This topic contains 1 reply, has 2 voices, and was last updated by  Saguaros 7 years, 1 month ago.
