  • fmfame Friend
    #192134
    I think fixel template has a little bug.
    If any of the menu effect like fading or scrolling is enabled, i can’t view on iphone or ipad in off canvas-menu the subitems, because they also have included this effect.. it looks like the subitems are transparent.. look at your own demo with enabled menu effects.
    phong nam Friend
    #512057
    Hi fmfame,
    On the light theme of JA Fixel template, the background color of Off-canvas sub-menu items gets white color style so that you think that they are not easy to view on iPhone. The idea is changing the color of menu items so that you can see it more clearly on mobile/ iPhone. You can try to create a custom.css file at templates/ja_fixel/css/ path and put below css styles into:
    #off-canvas-nav .t3-mainnav .t3-megamenu .mega-nav > li a,
    .t3-mainnav .t3-megamenu .dropdown-menu .mega-nav > li a {
    color: #333;
This topic contains 2 replies, has 2 voices, and was last updated by  phong nam 11 years, 1 month ago.
