  • ilhl Friend
    #934548
    I have a problem with the highlighting of the menu. I didn’t change any configurations so far, only installed the german language and switched to german. Also tried a few things with content (changing the title or text f.e.).
    I attached some pics to show what i mean exactly.
    Pic 1 is the starting site (photographer). Everything nice so far. The Home menu is highlighted.
    Pic 2 shows the site, when i scroll down. The "home" stays highlighted. Also in pic 3: i’m in the testimonial section, but the highlighting didn’t move and is still on "home".
    Pic 4 shows the "frontend developer" site. Here is seems to be correct. The highlighting moves with scrolling, the correct menu is highlighted.
    Pic 5 shows the blogger site. Scrolling seems to work fine – highliting is moving correctly.
    Pic 6 shows the click on blogger site. Also correct so far.
    Pic 7 shows the scrolling after the click. In this case i clicked the menu "contact" and got to that section. Then i scrolled up. The result is, that two menus were highlighted then – the one i have clicked ("contact") and the one i am actually at by scrolling ("gallery" in the pic).
    Pic 8 shows the same issue with "singer" site.
    Pic 9 shows the problem, that after i click other menus or scroll through the site and then come back to the start, the "home" is not highlighted anymore.
    1. 1-3
    2. 2-3
    3. 3-3
    4. 4
    5. 5
    ilhl Friend
    #934554
    here the pics 6 to 9
    1. 6
    2. 7
    3. 8
    4. 9
    Ninja Lead Moderator
    #935248
    I agree about the problems of your mentioning above. I also raised that bug to the development here
    Hope they will fix it next version.
    ilhl Friend
    #935305
    @ninja Lead
    on the Forum site it’s shown that this Topic has 3 Posts, last of which was created by you, but i don’t see it. Is it because it’s marked as internal or smth? Or did just smth go wrong?
    #938442
    @ilhl: Have you solved the problem on your site? Our dev checked the URL of your site but they could not see the problem on your site, see the video here
    ilhl Friend
    #938658
    no, i didn’t do anything.. it still there.. the devs are only clicking.. that’s ok so far.. but go to blogger site, scroll for example down till gallery, then click on testimonial, then click on contact and then scroll up again – u will end up with two menu highlighted..
    at least till you click again.. then it seems to be ok again, but then you go again and do that combination of clicking and scrolling, it will show up again..
    #938739
    This is a result testing scroll down on your site from our development here and they said it’s working well too
    ilhl Friend
    #938760
    #938781
    I got it and already forwarded this to the development team. Please give them a little time to check this.
    ilhl Friend
    #938785
    yeah, no problem.
This topic contains 9 replies, has 2 voices, and was last updated by  ilhl 8 years, 5 months ago.
