  • salvomic Friend
    #199478
    hi,
    I’m trying to get mobile version working, but I’ve some issues with menu:
    I can see only items set as “Child menu items” in Parameters (JA Extended), not those made as “Module”.
    Some items set as “External link” show but they revert to Home…
    Another question: how put logo in the top of mobile theme?
    Please, is there a tutorial how to do mobile (iPhone) version of JA Teline IV in Joomla 3.x?
    Many thanks in advance!
    Salvo
    Nazario A Friend
    #541468
    Hi Salvo,
    It would be best if you PM me the URL, Admin credential of your site so that I can check and help you out.
    salvomic Friend
    #541485
    sorry, web site administrator doesn’t like this… Please, kindly help me with some advice 🙂
    Nazario A Friend
    #541494
    @salvomic,
    It’s so difficult for me to help you. Please provide me some infomation:
    – The screenshot highlighting your problem.
    – Which template you are using JA Teline IV or JA Teline IV T3 ?
    I will try to check and help you out.
    salvomic Friend
    #541551
    thank you so much, Nazario!
    I’m using JA Teline IV T3 in Joomla 3.3.
    It’s a bit difficult for me to give a whole screenshot, I’m trying to post two or more…
    I’m trying to set mobile version using “Main Menu”; the items set as “child menu” appear in mobile setup, those with “module” not at all.
    See screenshot for “Parameters JA Extended” in Menu component:
    If one clic on the “Menu” in mobile setup (i.e. upon an iPhone) he can see only some items, not those with “modules” added, so he cannot navigate on those associated categories…
    Thank you again!
    salvo
    Add:
    module configuration screenshot
    1. Schermata-2014-07-08-alle-15.15.05
    2. no-in-menu
    3. yes-in-menu
    4. Schermata-2014-07-08-alle-15.15.27
    Nazario A Friend
    #541811
    <em>@salvomic 435705 wrote:</em><blockquote>
    </blockquote>
    The Parameters (JA Extended) is used to configure Megamenu (in T3v2, not T3). In the JA Teline IV T3, you can configure it in Megamenu Configuration.
    Add:
    </blockquote>
    By default, in the mobile layout, we disable all module on megamenu. If you want to show these module on menu, you can add this rule into file /templates/your_template_name/css/custom.css
    @media (min-width: 320px) and (max-width: 640px) {
    .t3-megamenu .hidden-collapse {
    display: block !important;
    Let me know if this helps
    1. Screenshot_34
    2. Screenshot_35
    Nazario A Friend
    #541834
    @salvomic,
    In T3 Framework, JA template has option “Hide when collapse” in Megamenu Configuration in backend. It helps to hide the column when the menu is collapse on small screen.
    In this case, this is best solution for you.
    – Go to Template Manager >> Megamenu Configuration
    – Configure the megamenu like this image:
    Hope this helps
    1. Screenshot_36
    salvomic Friend
    #541835
    hi Nazario, thank you.
    There is something wrong in my system: I cannot see any “Megamenu” or “Thememagic” option (see screenshot).
    Help 🙂
    salvo
    Version I’ve installed:
    1. theme
    2. Schermata-2014-07-10-alle-11.36.38
    Nazario A Friend
    #541951
    You are using JA Teline IV (base on T3v2 Framework), not JA Teline IV T3 (base on T3 Framework).
    As default, on the mobile layout, JA Teline IV does not show the module in menu item. This is old layout and we have stopped developing the T3v2 Framework.
    If you want to use the module in menu item, you can use the JA Teline IV T3 template.
    Hope this helps
    salvomic Friend
    #542011
    I’m now a bit confuse, hi 🙂
    I’m using T3v2: is it wrong?
    I could see no “Megamenu” or “Thememagic” option in template…
    So, I’ve installed now install JA Teline IV T3…
    I’ve installed JA Teline T3 quickstart and template from here:
    http://www.joomlart.com/forums/downloads.php?do=cat&id=510
    Now, if I choose to activate JA_teline_iv_t3 theme I get a blank page both in administration and frontend…
    (or better, I get this error: Fatal error: Cannot redeclare class T3Path in /home/…/public_html/plugins/system/jat3/jat3/core/path.php on line 191[/B])
    I’ve for now disabled the plugin: can I delete it definitely?
    I would like to use my megamenu (that use modules to get contextual menus in megamenu) also in mobile version, or almost to have a menu (in mobile version) like that…
    Please, help again 🙂
    Thanks in advance!
    salvo
    salvomic Friend
    #542046
    ok, Nazario,
    I’ve installed now JA Teline IV T3 and disabled the old JA T3 Framework.
    All ok, but I’m now setting all modules in the new positions…
    Salvo
This topic contains 11 replies, has 2 voices, and was last updated by  salvomic 10 years, 4 months ago.
