  • mickael n. Friend
    #1038516
    I have to do 2 menu for my links in the upper part the menu of my home page works well, but the second done anything could you help me?
    mickael n. Friend
    #1038583
    For information i have made too much modification in css and modules for make one update template yet.
    Pankaj Sharma Moderator
    #1038644
    The submitted login and password not working, can u check the and provide working details, so that I will have a look on this issue.
    mickael n. Friend
    #1038688
    Hello the user and password are working. are you on to be on the right site http://bibconsult.microbib.fr ? It is very urgent now because the site must be online today thank you
    #1038723
    Support menu is working at my end.
    Can u check it again: http://prntscr.com/fejpjl
    mickael n. Friend
    #1038755
    Yes, but like i say on the older messages. If you link : http://bibconsult.microbib.fr/index.php/catalogue-en-ligne and you click on : _NOS PRODUITS or _SUPPORT it is do not work
    #1038765
    Publish the module nos products on this page just like the homepage
    http://prntscr.com/felb6t
    As u can see there is no module on this page to link this is why link not working.
    mickael n. Friend
    #1038770
    Yes but if i make the link on index.php/#nos_produits it do not work ?? it always put this link :
    http://bibconsult.microbib.fr/index.php/catalogue-en-ligne#nos_produits
    #1038780
    add /index.php/#nos_produits in the link if you want to move the link on the home.
    link is used to work on the same page.
    mickael n. Friend
    #1038784
    Yes i have understand . But heaven if put :
    http://bibconsult.microbib.fr/index.php/#nos_produits
    it do not work try it and see …
    mickael n. Friend
    #1038786
    Yes i have understand . But heaven if i put :
    it do not work try it and see … you can find it in "menu site"
    i don’t know why it is integer name of the page before #
    mickael n. Friend
    #1038811
    It looks like a script in the mega menu because the same link in the sidebar works.
    #1039239
    Yes, there seems some issue.
    I shared the issue with the development team, its holiday on weekends i can give you track requestion on Monday.
This topic contains 12 replies, has 2 voices, and was last updated by  Pankaj Sharma 7 years, 6 months ago.
