  • lailuluelo Friend
    #173995
    Hello friends,
    I have Joomla 2.5 and Ja Droid with multilanguage so when I try to select the position of the menu like the horizontal position just under the header, like the demo, I can´t choose because I can´t find it? I only installed the template, I need to install something more?, Is configuration problem?
    Thank you in advance 🙂
    TomC Moderator
    #438728
    Can you clarify your issue a bit further?
    Are you trying to assign a particular menu style? – i.e. dropline, css, mega ??
    lailuluelo Friend
    #438908
    I would like a menu like the demo:
    I can´t, Idon´t have the position top.mainnav
    I see in my template.css the information about this module but…
    /* NAVIGATION
    /* Main Nav ---*/
    #ja-mainnav {
    background: url(../images/mainnav-bg.gif) repeat-x left top #18223B;
    border-top: 1px solid #3C5189;
    position: relative;
    z-index: 22;
    Thank you
    1. menu
    lailuluelo Friend
    #438989
    Could anybody help me?
    I don´t know why can´t I select the position top.mainnav included when I choose the position of the menu.
    Thank you
    TomC Moderator
    #439037
    Can you please provide the url of the site you’re working on – so we can take a look at what it is you are seeing/not seeing?
    lailuluelo Friend
    #439052
    <em>@TomC 301565 wrote:</em><blockquote>Can you please provide the url of the site you’re working on – so we can take a look at what it is you are seeing/not seeing?</blockquote>
    I send you a private message, because the site is desactivated.
    I can´t find the section to provide private data access in this post-
    TomC Moderator
    #439076
    When you uploaded/installed your JA Droid template …. did you do so utilizing the quickstart+sample data installation process?
    It looks as though you’re attempting to re-invent the wheel here, when you can simply start from a virtual clone of the demo site and keep/disable the items you want/don’t want very easily.
    lailuluelo Friend
    #439131
    <em>@TomC 301610 wrote:</em><blockquote>When you uploaded/installed your JA Droid template …. did you do so utilizing the quickstart+sample data installation process?
    It looks as though you’re attempting to re-invent the wheel here, when you can simply start from a virtual clone of the demo site and keep/disable the items you want/don’t want very easily.</blockquote>
    Sorry, but I don´t want to reinvent nothing. Is simple, I installed Joomla 2.5 without examples, clean, then I install your template and after began to make a web multilingual. I try only to say the aplication that I wan´t to put this menu in that position, like the demo, in the position top.mainnav… Do you say that I tried to make something paranormal?
    I´m sorry but I’m disgusted. I don´t like kill flies with canions…
    I’m try to do myself :((
    TomC Moderator
    #439132
    <em>@lailuluelo 301678 wrote:</em><blockquote>I don´t like kill flies with canions…
    I’m try to do myself :((</blockquote>
    Actually, killing flies would be wiping the slate clean and starting fresh – utilizing the following step-by-step tutorial for installing your template using the quickstart+sample data installation method – which provides you with a virtual clone of our demo site to start with.
    In the alternative, you could utilize our DEMO BUILDER as a tool to cross-check your own configurations with those of our demo version.
    lailuluelo Friend
    #439135
    <em>@TomC 301679 wrote:</em><blockquote>Actually, killing flies would be wiping the slate clean and starting fresh – utilizing the following step-by-step tutorial for installing your template using the quickstart+sample data installation method – which provides you with a virtual clone of our demo site to start with.
    In the alternative, you could utilize our DEMO BUILDER as a tool to cross-check your own configurations with those of our demo version.</blockquote>
    Really, I’m pleased with your help but I try to know why is not working.
    TomC Moderator
    #439136
    <em>@lailuluelo 301683 wrote:</em><blockquote>Really, I’m pleased with your help but I try to know why is not working.</blockquote>
    The choice, of course, is yours . . . . I was simply tryng to offer up alternatives to help speed your site development process along – as opposed to you continuing to be frustrated and losing more time.
    Nevertheless …. good luck with your continuing site development.
    lailuluelo Friend
    #439139
    I know that sometimes, is worst try to fix problems, is better from the begining… But It isn´t my first installation, I´m not an expert in Joomla but I would like to find the error because I didn´t erase anything. An I thought that a real expert like you can try to help me, looking for the problem but I think also you have a lot of work.
    Sorry
This topic contains 12 replies, has 2 voices, and was last updated by  lailuluelo 12 years, 9 months ago.
