  • kikra Friend
    #147799
    In the first time sorry for my pretty bad english, and I will try to explain my problem with my best english ^^”
    So, I have download templates JA TELINE III but I can’t change the menu system, it’s always on dropline menu and I want it in Moo menu with a horizontal sub menu…
    If anyone can help me with this problem…Thank You…
    micrantha Friend
    #329790
    You can change Menu Type in Template Manager. Just open JA_Teline_III and you can find the parameter.
    Good luck,
    Micrantha
    kikra Friend
    #329791
    Yes I have tried but it’s not working…
    micrantha Friend
    #329792
    OK kikra,
    Take a look at this post.
    There is a bug in version 1.4
    You can find the fix there.
    Good luck,
    Micrantha
This topic contains 4 replies, has 2 voices, and was last updated by  micrantha 14 years, 10 months ago.
