  • bobptz Friend
    #1000366
    I noticed that when I resize the browser and the width is somewhere at 2/3 of the screen width, the search field overlaps the last menu item to the right.
    I will rearange my menu and I do not think I will have an issue with the final version of the website. If there is an easy fox, please tell me. Otherwise I just want to report this issue.
    1. purity-menu
    Hello
    Could you share your website url ?
    bobptz Friend
    #1000380
    bobptz Friend
    #1000557
    Hello
    Have you looked at it? Is there a fix?
    Hello
    Try this
    In your custom.css file add :
    @media (min-width: 991px) {
    .navbar-nav {
    margin:9.75px -80px!important;
    bobptz Friend
    #1000568
    Thank you for the code.
    It seems to be dependant from the total size of my menu. When I finalize my menu, I will test again and use your some with different numbers maybe.
    Ok
    Let us know if it works
This topic contains 6 replies, has 2 voices, and was last updated by  pavit 7 years, 11 months ago.
