  • propolis Friend
    #758518
    Hi, I am using JA Biz template v1.1.4 and Joomla 3.4.5 I have created 2 styles each using its own menu. The site has just started started to be developed, but I wanted to check that the template / styles / menus will work as I will be using 8 styles / themes. This is the main site link: Main Home Page Here you can see Home is Orange with a outline around it. Now you will also see there is a menu option called ‘Country’. Here you will find a drop-down menu called ‘UK’ – click this option. You will be taked to the UK site which uses its own menu structure and its own theme. Now when you look at the page that shows, there is nothing showing as such and the menu buttons shows as black inactive buttons. Now click on the ‘Home’ button and the page changes , various modules show and the ‘Home’ menu button is Orange with an orange outline. Now under ‘Country, there is a sub-menu that says ‘International Site’ – click on this button and you will go back to the main ‘Home’ page. Here you will see the full menu structure, no active buttons and nothing showing. Now when you click on ‘Home’, it turns Orange and the full page gets displayed. Any idea how I can fix this behavior for the menu linking to different themes to work correctly. 🙂 It does work fine in the Purity 3 template. Thanks for any help / assistance provided Eddie
    Ninja Lead Moderator
    #758822
    I set the config “Home [UK]” menu to back Home menu with original theme.
    If I are mis-understanding your enquiry, you can give me the screenshot and description of what you are trying to do. I will help you to check it.
    propolis Friend
    #758888
    <em>@Ninja Lead 504678 wrote:</em><blockquote>Hi,
    Regards</blockquote>
    Firstly, thank you for your assistance. What you have proposed is not correct.
    Here is the link to the document Document showing the process what needs to be achieved.
    This process can also be seen working with Purity3 here: Working Site where you will see the interaction between different countries working
    Let me know if you need any more information.
    Eddie
    #758900
    I have read from your docs above and it like you are trying to make multi language on your site and you want to link from
    + On International menu click UK menu under Country page and link to UK home
    + On UK menu click International Site menu under Country page and link to International of home page
    You can check the my configuration and let me know if it helps
    propolis Friend
    #759036
    <em>@Ninja Lead 504780 wrote:</em><blockquote>I have read from your docs above and it like you are trying to make multi language on your site and you want to link from
    You can check the my configuration and let me know if it helps</blockquote>
    That looks like it is working correctly.
    Would it be possible to let me know what you did to get it working so that I can add the other 6 countries
    Thanks again for your help
    Eddie
    #759038
    I used Menu Item Type with Menu Item Alias, you can see it from both my screenshots
    propolis Friend
    #759101
    I have just added another country to make sure I got it right and its all worked well.
    Thank you for your quick response and help
    Eddie 🙂
    #759102
    Let me know if you have any further assistance.
This topic contains 8 replies, has 2 voices, and was last updated by  Ninja Lead 9 years ago.
