efficiency Friend
efficiency
- October 2006
June 2, 2015 at 9:04 am #206821Mobile menu only works on the home page. For all inside pages, if you click on the menu, it just brings up the search.
See pictures.
This issue can be easily simulated on http://mobiletest.me/.What is wrong with the template (or me)?
Pankaj Sharma Moderator
June 2, 2015 at 10:21 am #572590Hi
There are different template style are present on the site .
JA Charity template style is used for homepage and other pages using default template style or other styles
here >> http://prntscr.com/7c49or
Off canvas menu is coming through the module published on the off canvas module postion .
Go to module manager >> Open module that is on Off=canvas module position .
Check options >> Menu assignments .
Here is a documentation for menu system.
Hope it helps .1 user says Thank You to Pankaj Sharma for this useful post
efficiency Friendefficiency
- October 2006
June 2, 2015 at 11:00 am #572592Thanks, that fixed it.
Viewing 3 posts - 1 through 3 (of 3 total)This topic contains 3 replies, has 2 voices, and was last updated by efficiency 9 years, 6 months ago.
