  • zombiesonice Friend
    #176065
    when i try to edit any mod_customs modules in the kranos package i am given the following error
    “Fatal error: Call to undefined method stdClass::onDisplay() in /public_html/libraries/joomla/html/editor.php on line 268”.
    Can you help?
    ty
    TomC Moderator
    #448240
    Can you explain a bit how you are trying to edit your mod_custom module(s) and/or what you are wanting to achieve?
    zombiesonice Friend
    #448288
    well the problem is that you cant make even the simplest edit because when you open one of Kranos’s pre made custom modules to edit it. you are given this error.
    zombiesonice Friend
    #448297
    I found the problem and solution in another thread
    http://www.joomlart.com/forums/topic/article-editor-error/
    I think this may be a problem for others. Can you post in solved issues or make a sticky for it.
This topic contains 4 replies, has 2 voices, and was last updated by  zombiesonice 12 years, 8 months ago.
