mayhesla Friend
mayhesla
- April 2008
- 5 times in 1 posts
April 29, 2008 at 12:38 am #128020Hi
I have a problem (at least in Firefox) with the text banner module = _text
If i publish it in right or left column with more than 3 modules – the header of the module breaks up.
See attached image – anyone else having the same issue?
regards
me
Sherlock FriendSherlock
- 2478 times in 2162 posts
April 29, 2008 at 1:48 am #247180Hi mayhesla !
It’s best if you send link of your site !mayhesla Friendmayhesla
- April 2008
April 29, 2008 at 4:50 am #247213Hi
Oki – i’ll put up a module there for a while so you can check it out 🙂
http://3wpoker.com is the location…
- April 2008
April 29, 2008 at 2:11 pm #247263Hi again
i seriously cant have a module published that breaks the layout – to much longer.
If i am gona show a link with an example of this problem = it would be reall cool if it could be checked as soon as possible. I am taking down the example in a couple of hours. I guess i’ll just be stuck with the problem if no reply by then 😉
bigrk Friendbigrk
- February 2007
- 45 times in 15 posts
April 29, 2008 at 2:40 pm #247266What happens when you unpublish Statistics?
- April 2008
April 29, 2008 at 6:58 pm #247302Hi – check it out on the site now (3wpoker.com)
I have disabled the module – and all is fine with the _text module then. If it’s with another module, the “other” module gets it’s header messed up…(doesen’t mather what type of module i publish)
thx for helping btw 🙂
bigrk Friendbigrk
- February 2007
April 29, 2008 at 7:51 pm #247306When publishing the Statitics Module, do you publish it only to the home page or are you trying to publish it to all pages?
- April 2008
April 29, 2008 at 8:21 pm #247308Hi
I have published it both on frontpage only – and on all pages. Same result if i use the _text prefix for 1 module.
I have published a test module on these two pages now:
http://3wpoker.com/
http://3wpoker.com/about-us.htmlboth give same result – and the last page is a static page.
thx
AuthorPostsViewing 8 posts - 1 through 8 (of 8 total)This topic contains 8 replies, has 3 voices, and was last updated by mayhesla 16 years, 4 months ago.
Problem with mod style = _text
