  • wsmcos89 Friend
    #148806
    I don’t know how to set the class module, because there is not the field Class Module
    Take a look
    Anonymous Moderator
    #333117
    Hi wsmcos89
    in the case, please open modulesmod_ja_contentscrollmod_ja_contentscroll.xml file, find following code section:
    <param name="catid" type="category" default="" label="CATEGORY" description="CATEGORY DESC" />
    <param name="sort_order_field" type="list" default="created" label="SORT ORDER BY" description="SORT ORDER BY DESC">
    <option value="created">DATE</option>
    <option value="ordering">ORDER</option>
    <option value="hits">HITS</option>
    </param>
    and change to:
    <param name="moduleclass_sfx" type="text" default="" label="Module Class Suffix" description="PARAMMODULECLASSSUFFIX" />
    </param>
    wsmcos89 Friend
    #333147
    Thanks, it’s ok now for me.
    wsmcos89 Friend
    #333727
    What is the class of green bar?
    Anonymous Moderator
    #334082
    Hi you
    It is from div.moduletable_hilite class
    Please open template.css file, find this class to change
This topic contains 5 replies, has 2 voices, and was last updated by Anonymous 14 years, 10 months ago.
