  • eric67 Friend
    #136983
    I have a problem with mod_ja_contentscroll module. I just installed a new package from quickstart. I use Joomla 1.5.8.
    I wanted to modify the title of the module to translate in French language. This is the only option I modified and then saved (I set Include Mootools library to yes too). The problem is I have now the title in the module menu bar without any color. I saw on the forum that there is a parameter like “_black” for example for the Module Class Suffix field, but I can’t see a such field??? Of course, Include Mootools Library is set to yes.
    Any idea ?
    May be I made a mistake somewhere but this is my very first install using Joomlart technology.
    Please apologize for my bad English.
    regards,
    Eric.
    Anonymous Moderator
    #286027
    Please send me your live url, admin account via PM so that i could have closer look on the issue.
    bassfade Friend
    #286218
    <em>@eric67 105377 wrote:</em><blockquote>Hello,
    Any idea ?
    regards,
    Eric.</blockquote>
    doesn’t it also appear to me the field “module class suffix” where to put “_black” as I can do??
    the module mod_jacontentscroll has been loaded from your dowloads!!
    eric67 Friend
    #286293
    I sent you a user ID / pwd and the link of the site yesterday. Could you please have a look?
    Thanks a lot.
    Eric.
    andreasschwarz Friend
    #298329
    Hello, i have the same Problem. What can i do?
    Thanks for information
    Andy
    eric67 Friend
    #298370
    Easy to fix.Just have a look to this post :
    http://www.joomlart.com/forums/topic/module-class-suffix-17/
    Eric.
This topic contains 6 replies, has 4 voices, and was last updated by  eric67 15 years, 9 months ago.
