April 15, 2010 at 3:35 pm #150391
I have a problem with the width of the module mod_ja_slwi. I’ve positioned it in user1, user2 or user5 but the module never had the correct width. It is everytime cutten nearly excact in the middle.
Please have a look at: http://bem-solar.de/cms/index.php
I have tried out every solution and fix which I could find here, but nothing helped.
I would be grateful if somebody could help me…
Thanks in advance.
Eugene
- 2008 times in 1700 posts
April 16, 2010 at 1:06 am #340520Hi you
I think this issue is from your configuration. Try to check your admin account
Also, could you send me your admin account via PM so that i can debug it for you
April 16, 2010 at 10:23 am #340569thank you…
I’ve send you a PM with the information.
April 20, 2010 at 8:24 am #340883Is there nobody who could help me? I have no fix till now, but I need this module!
Please help me….Anonymous ModeratorJA Developer
April 22, 2010 at 8:18 am #341158Thank you for your reply.
I have downloaded and installed the newer version. The width is correct now but I got a new problem…
I think that this is a template bug now (or missconfiguration from my side…). In the description on joomlart I can see that user1, user2 and user5 should be in one row.
I am using exactly this positions with three mod_ja_slwi modules but they appear in two rows.
I don’t know where the problem is. :confused:Here the link: http://www.bem-solar.de
Thank you very much in advance.
April 27, 2010 at 8:26 pm #341836Hi JA Developer,
it seems to work fine. But in the template demo the positions user1, user2 and user5 are in one row, and not in two rows.
Is this a special configuration? Or do I have to modify the css-file?
Thank you in advance…
May 4, 2010 at 9:45 pm #342668Hi,
I’ve edited the file with the code you posted. But it still doesn’t looks like the demopage.
Maybe your next fix will work 😉May 4, 2010 at 9:55 pm #342674<em>@bemsolar 177415 wrote:</em><blockquote>Hi,
Maybe your next fix will work ;)</blockquote>sorry for replying to quick… :-[
Now it works fine. Instead of your 50%, I took 30% and now it seems that everything works how I need it.
But I have still a last question: (I swear It will be the last one for this week :D)
–> Is it possible to have a padding-left inside the expanding textarea from the module? -
This topic contains 12 replies, has 2 voices, and was last updated by Anonymous 14 years, 6 months ago.
