  • eric67 Friend
    #138537
    I tried to copy the module mod_ja_vmproductslide. I would like the first one displays only a precise category and the second one another category.
    There are 2 problems:
    1 – even if I have two different ID category number it is always the same which is displayed
    2 – The duplicated module is empty but in the first one, I can see a “mixed” line of product
    Sorry for my bad English, I hope you can understand what I mean. Please have a look on my test site.
    Any idea how to solve that problems ?
    You can see the problem here http://test.yoosite.fr
    The module “WHAT’S NEW HERE” and the copied one “COPY OF WHAT’S NEW HERE” just below.
    Eric.
    jsliao Friend
    #293349
    this is most likely due to both modules sharing the same set of variables. when u copy the module, u need to also make sure that the variable names in each module is different. otherwise.. they will just be duplicates literally
    eric67 Friend
    #293583
    Thanks.
    I see what you mean. I guess that problem can’t be easily solve. Probably many files to modify…
This topic contains 3 replies, has 2 voices, and was last updated by  eric67 15 years, 10 months ago.
