  • lulubug Friend
    #138185
    Hi there
    I need to have 5 elements in my mod_jacatslwi however when I go to configure this it shows 5 elements but not on the same line.
    As soon as I make it 5 elements the last 2 always move down one line. It doesn’t matter whether I have made the pictures smaller, what I change the default size to, whether or not I have auto re-size on or off, the images wont all appear on one line.
    After doing some fiddling it seems as though the issue is the background. While the image sizes correctly, the background stays on width 223. I have tried to fix this but nothing I seem to try is working.
    Please could you help me with this asap.
    Lesley
    P.S. Great template otherwise 🙂
    Anonymous Moderator
    #292012
    Hi lulubug,
    Could you please send me your live url, admin account via PM so that i could have closer look on the issue?
    lulubug Friend
    #292016
    Hi There
    Thanks for your reply, I have posted this issue (and 2 others) in the same post with screenshots: http://www.joomlart.com/forums/topic/physical-exercise-is-good-for-mind/
    Unfortunatly I am still working on this on localhost so can’t give you access.
    If the screenshots don’t help please let me know and I will try and get a live version up.
    Thanks 🙂
    archerwebsolutions Friend
    #293426
    I am also having this problem. I am not able to get five instances to display in one row, regardless of size.
    http://archerweb.com/~ekojirch/dev2/
    nadgobxe Friend
    #293429
    i have the same problem 🙁
    criticalkaos Friend
    #293994
    any answer to this problem yet?
    Anonymous Moderator
    #294939
    hi,
    It is very difficult to debug this issue if i don’t have your live url.
    Please try to upload your code to a server and send me your information so that i could have closer look on the issue.
    #295043
    http://archerweb.com/~ekojirch/dev2/ is live, with 4 spots currently. Do you need back-end login information?
    Anonymous Moderator
    #298130
    Hi archerwebsolutions,
    I have checked your website and saw that 5 elements have the same size.
    did you have fixed this issue?
    #298303
    We had a css expert come in and help us adjust the values.
This topic contains 10 replies, has 5 voices, and was last updated by  archerwebsolutions 15 years, 9 months ago.
