  • latinosusa Friend
    #140993
    Hi everybody.
    This is my first post.
    I trying to put up a site using This template. JA Quartz
    everything is going ok.
    I used the quick install with joomla 1.0
    here is a link to the site
    http://lametrofm.com/metro/index.php?option=com_frontpage&Itemid=1
    my problems are
    1- no matter what images i put in the contents to be used , the mod_jacatslwi will not show it.
    i only see the title and a small description.
    2- the heigt of the front page will not adjust when i increase the amount of published modules and contents,
    it is fixed to certain height .
    i want the height of the page to adjust automatically according to the amount of contents in it.
    i will apriciate any help.
    thanks in advance:)
    nguyenhuu quang Friend
    #304012
    1. pls use Joomla 1.5.10 quickstart.
    2. i cant see your problems
    thanks
    latinosusa Friend
    #304393
    <em>@quang268 127831 wrote:</em><blockquote>1. pls use Joomla 1.5.10 quickstart.
    thanks</blockquote>
    thanks for replying:D
    i already fixed:cool:
    solution for images problem.. images must be uploaded to stories sub folder and applied using the include image option on the joomla editor, i does not work with images added from external links.>:(
    the resizing of the page was not problem at all, just a bad interpretation in my part.:((
    Pd:
    I do not like joomla1.5:((
    it has to many difficulties and MooTools errors with IE 8, and unfortunately most of my visitors use Internet explorers.>:(
    I will just wait for Microsoft to make IE more compatible with joomla 1.5:((
This topic contains 3 replies, has 2 voices, and was last updated by  latinosusa 15 years, 8 months ago.
